1. AC Question's Avatar
    BUT, take the battery out, put it back in, and it charges fine. And the battery holds the charge well.
    Have used different charger and different cable, same results. It is my daughter's phone 900 miles away, so I'm hesitant to say master reset unless I'm pretty sure that will fix it. Any ideas on this?
    03-18-2015 09:10 PM
  2. Rukbat's Avatar
    Wipe the battery contacts and the contacts in the phone that connect to them with a swab wet with alcohol. If that fixes it even temporarily, use a slightly rougher cloth, but gently. There could be an oxide build-up on one of the contacts. (Alcohol isn't water, it won't wet the phone - if anything it'll absorb any moisture already there.)
    03-18-2015 11:21 PM
  1. Why won't my Galaxy S5 stay connected to my Jeep's uConnect?
    Last Post: 03-21-2015, 10:56 PM
  2. Galaxy S4: Music randomly pauses and starts?
    Last Post: 03-19-2015, 03:01 PM
  3. Replies: 1
    Last Post: 03-18-2015, 10:19 PM
  4. Galaxy S5 interfering with cable service
    Last Post: 03-18-2015, 10:13 PM
  5. Replies: 1
    Last Post: 03-18-2015, 10:10 PM
