1. AC Question's Avatar
    I recently purchased a amplifier/repeater which operated from 750 to 2100 MHZ and tried it at my remote lake home. I know that the signal exits at my location since my neighbors can use similar equipment. I returned home to Spokane WA and tried the equipment at my home where the signal is normally weak. No change in signal strength was registered on the phone. I made sure that the antenna was located with a solid outside wall separating it from the repeater.
    Is my phone compatible with the operating range of the repeater?
    Thank you in advance.
    Randy Melcher
    04-01-2015 08:11 AM
  2. itguyjax8430's Avatar
    Randy Melcher
    You need to know what frequency the signal is for that cell tower you are near. Also using a repeater could cause issues to the reception since it is not tuned correctly and could cause interference. What carrier are you with? Most carriers offer a signal boaster that you can plug in to your home internet connection to boast your signal at home.
    04-01-2015 10:55 AM
  1. Problems with ATT update from March 30 2015
    By Pendrewski in forum AT&T Samsung Galaxy Note 3
    Last Post: 04-18-2015, 04:23 PM
  2. Replies: 7
    Last Post: 04-02-2015, 08:58 AM
  3. My Samsung S3's touchscreen doesn't work, what should I do?
    Last Post: 04-01-2015, 11:09 AM
  4. From M7 to S6 Edge my thoughts
    By 05 TypeS DC5 in forum Samsung Galaxy S6 edge
    Last Post: 04-01-2015, 08:12 AM
