1. AC Question's Avatar
    Recently done a software upgrade on my samsung s3,but i cannot put a call on hold to answer another call or put a call on hold to ring another.was ok before upgade
    can someone please help.
    05-01-2015 02:35 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Can you show us a screenshot of what your dialer looks like when it's in a call? http://forums.androidcentral.com/amb...d-central.html
    Which update did you get? Is your S3 on KitKat now? When you get a call while you're on a call with someone else, look at the screen--it should prompt you if you want to answer the call or ignore it. If you answer the call, the other call should be put on hold. When you finish the 2nd call, it should dump you back into the 1st call. Is that not happening?
    05-01-2015 10:49 PM
  1. I can't transfer files fom Kindle Fire to my Laptop
    Last Post: 05-01-2015, 10:56 PM
  2. Replies: 1
    Last Post: 05-01-2015, 10:51 PM
  3. Multiple Call Capabilities
    By Grayf0x in forum Samsung Galaxy Note 4
    Last Post: 05-01-2015, 05:55 PM
  4. No special external SD permissions on 5.0.1
    By mike21582 in forum Legacy Android & Other OS's
    Last Post: 05-01-2015, 03:29 PM
  5. Samsung SideSync 3.0 - Any Users?
    By BioFanatic in forum Samsung Galaxy S6
    Last Post: 05-01-2015, 02:45 PM
