1. AC Question's Avatar
    My s3 all of sudden started lagging alot few weeks ago and I also cant make a phonecall or receive one without restarting my phone,even then it still doesnt work normally.I factory reset it and cleared the cache in that volume up screen thing but the problem is still there.
    06-10-2015 08:24 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try booting into Safe Mode, which temporarily disables all 3rd party apps. s3, safe mode, i9300, ,GT-I9300
    If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
    06-10-2015 11:53 AM
  1. Replies: 1
    Last Post: 06-12-2015, 10:45 AM
  2. Asus Zenfone 2 or Samsung E7? help pls
    By marktika in forum ASUS ZenFone 2
    Last Post: 06-10-2015, 06:39 PM
  3. Replies: 1
    Last Post: 06-10-2015, 11:54 AM
  4. Replies: 1
    Last Post: 06-10-2015, 07:54 AM
  5. Why isn't my indicator light on my Samsung Note4 showing?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 06-10-2015, 07:46 AM
