1. AC Question's Avatar
    I have a galaxy s3, model SGH-T999. I have been trying to flash a ROM (Carbon ROM, to be specific), but have not been successful. I have little experience with rooting & ROMs, so guidance on what to use would be extremely helpful.
    What I have done so far is downloaded the zip files (both the main and gapp) and tried to flash them with the flashify app. Each time I get "E: failed to verify whole signature. Installation aborted." Any tips on how to fix this / different apps or methods?
    08-27-2015 11:32 PM
  2. Rukbat's Avatar
    Download from where an MD5 signature is posted. Use an MD5 program to verify the MD5 of the files you download. (That's usually what causes a signature failure - the file's MD5 doesn't match what it should be because you got a bad download.)
    For further help, fins the Carbon developer (probably on XDA) and ask.
    08-28-2015 12:30 AM
  1. Setting for not having calls go to the Gear 2 neo
    By ronr9286t in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 08-28-2015, 07:39 AM
  2. Polaroid PMID710 7" 4gb Tablet -HELP ME!!!
    By Splash13y in forum Ask a Question
    Last Post: 08-28-2015, 12:17 AM
  3. Why is Cell standby one of the top things using up my battery?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 08-28-2015, 12:11 AM
  4. Replies: 1
    Last Post: 08-27-2015, 10:59 PM
  5. HELP My LG Optimus F7 By Boost Won't WORK, how can I fix it?
    Last Post: 08-27-2015, 10:57 PM
