1. AC Question's Avatar
    Yesterday I dropped my Galaxy S3 in the toilet. I picked it up, then dried it first with a towel and then with a blow dryer. I left it with battery and sim card out for a night and then tried turning it on in the morning. Suprisingly, everything was fine except from the screen. It is super dim, like when your battery is almost out. I charged it to 100%, tried turning it off, turning screen brightness to the max, turning off the power saving mode and everything, but nothing seemed to work. Then, suddenly when I looked at it later, it was all bright and normal again. However, it only lasted for few hours and now I'm stuck with a dark screen again. I don't want to get the screen changed or anything because this is just my back up phone for few months or so, but is there anything I could possibly do to make it brighter?
    09-06-2015 05:02 PM
  2. srkmagnus's Avatar
    Unfortunately that's the result of water damage. Water does weird things, and sometimes it takes a while before the problems set in.. Oh need to replace the screen. Being that you don't want to do that, you'll need to replace the device.
    09-06-2015 05:14 PM
  1. Replies: 1
    Last Post: 09-13-2015, 03:38 AM
  2. How can i check my message history on samsung note 2 phone
    Last Post: 09-06-2015, 05:18 PM
  3. Replies: 1
    Last Post: 09-06-2015, 03:38 PM
  4. How do I get a Samsung Note 4 S View cover to work without the prongs?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 09-06-2015, 01:18 PM
  5. Replies: 0
    Last Post: 09-06-2015, 01:06 PM
