samsung 3 stuck on safe mode
I have tried turning off and back on. I trued a reboot. I removed the battery. nothing works. I have noticed the volume button is not always working.
Re: samsung 3 stuck on safe mode
Welcome to Android Central! Does Volume Down work? If not, it might be broken, constantly registering as being pressed. If you press and hold Vol Down during the boot process, it goes into Safe Mode. You'd probably have to take it to a repair shop to fix it.
Originally Posted by
AC Question I have tried turning off and back on. I trued a reboot. I removed the battery. nothing works. I have noticed the volume button is not always working.
Problem solved fellas. Either the volume button got sticky from soda or something, or was dropped and bent the pressure point. Behind the button. I took mine apart screws and all, unplugged every component, took the motherboard out and cleaned everything with alcohol to no avail. Them I took the volume button out, just pulled it out with my fingernails, and used a thin knife to scrape around the bottom point of the volume button, (on the phone itself not the plastic button). Now it starts fine but the volume down sticks a lil still. Hope this helped.
