1. AC Question's Avatar
    I have tried turning off and back on. I trued a reboot. I removed the battery. nothing works. I have noticed the volume button is not always working.
    09-14-2015 01:35 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does Volume Down work? If not, it might be broken, constantly registering as being pressed. If you press and hold Vol Down during the boot process, it goes into Safe Mode. You'd probably have to take it to a repair shop to fix it.
    09-14-2015 07:05 PM
  3. AJStClair's Avatar
    Problem solved fellas. Either the volume button got sticky from soda or something, or was dropped and bent the pressure point. Behind the button. I took mine apart screws and all, unplugged every component, took the motherboard out and cleaned everything with alcohol to no avail. Them I took the volume button out, just pulled it out with my fingernails, and used a thin knife to scrape around the bottom point of the volume button, (on the phone itself not the plastic button). Now it starts fine but the volume down sticks a lil still. Hope this helped.
    11-19-2015 08:17 AM
  1. Car Mode or Hands Free Mode
    By jake14mw in forum Samsung Galaxy S6
    Last Post: 10-29-2015, 01:17 PM
  2. Replies: 3
    Last Post: 09-18-2015, 11:49 PM
  3. Replies: 2
    Last Post: 09-15-2015, 06:14 AM
  4. Group messaging is not working on my S5, Why?
    By Martins2501 in forum Ask a Question
    Last Post: 09-14-2015, 07:06 PM
  5. Replies: 1
    Last Post: 09-14-2015, 02:03 PM
