1. AC Question's Avatar
    I have a Straighttalk Samsung Galaxy S3. It is in talkback mode. I have a 4 digit pin code on the front screen. I cannot get past this screen in order to turn off talkback.
    01-09-2016 08:29 PM
  2. Javier P's Avatar
    Have you already tried double tap to enter the code? In some phones you need a triple tap.
    01-09-2016 08:31 PM
  3. mommafox65's Avatar
    Yes< I have double tapped and triple tapped
    01-09-2016 08:37 PM
  4. Javier P's Avatar
    Thanks for registering and welcome as a new member! You could try this.
    Long press and then double tap in the password field to pull up the keyboard.
    Enter your password with long presses on the keys.
    Double tap 'Done'.
    01-09-2016 09:07 PM
  1. I transferred music from iTunes account to my Galaxy Note 4
    Last Post: 01-10-2016, 05:04 PM
  2. Help on home screen
    By Mike Heppe in forum Samsung Galaxy Note 5
    Last Post: 01-10-2016, 12:40 PM
  3. How do I switch my voicemail app and inbox on Android?
    Last Post: 01-09-2016, 11:11 PM
  4. How can I disable the hot button?
    Last Post: 01-09-2016, 11:09 PM
  5. Replies: 1
