A Big Problem With Samsung S3 GT-I9300, Can Anybody Help ?
miro2010alex
Hello every body,
I have a big problem I think with Samsung S3 GT-I9300, It was working good and once it stooped working and keep on the black screen which is written on it Samsung S3 and never startup
and when I Try booting into recovery it displays like this
and when i try to factory reset or wip cache partition it displays this
I tried to install a jeelyBean or any system from SD card it displays
I tried to install a framware upgrade with Samsung Kies it works for while and stats the upgrade and stopped displays this
please advice me what can i do in this case ?
Every time I use my cellularone gt i9300, it just keeps showing live |||| Connected and boot animation is 0.15x
How do I fix it?
And my other one is not working anymore since 2018.
Does anyone else have that issue?
How do I fix it?
Hi, welcome to AC!
This is a older thread and most members here have newer device , s3 is considered a dinosaur , you can try flashing the firmware with odin if you can find the firmware for it , can try Xda forums otherwise maybe hardware issue.
r3dpuk3
