1. AC Question's Avatar
    I messed up badly, I was trying to install cyanogenmod mod on my phone, to do this I installed twrp, and all was going well until for some reason I was unable to install the cyanogenmod. I was a huge ***** and forgot to back up, I cleared everything so now my phone has no OS. I tried installing 4.4.2 through ODIN, but I keep getting the same error no matter what version I use, Secure Check Fail : aboot, I was browsing the forums and discovered I that I am in need of a PIT file, so I did that, then I got 2 errors, Secure Check Fail : PIT and Secure Check Fail : aboot, please help me, I just want to use my phone again. For reference, I installed TWRP(v2.2.2.0) through the playstore, I've tried ODIN3 3.04,3.07 and 3.09. I got the tar.md5 from samsungs official website, 4.4.2.
    03-30-2016 07:29 PM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    Try this guide below, it should return you to complete factory and you can then start your rooting process over from there.
    http://forums.androidcentral.com/amb...sung-kies.html
    04-04-2016 08:39 AM
  1. Why won't my apps download over wifi?
    Last Post: 04-23-2016, 09:14 AM
  2. Replies: 6
    Last Post: 04-12-2016, 03:31 PM
  3. Replies: 1
    Last Post: 03-31-2016, 04:19 AM
  4. my s6 will not turn off
    Last Post: 03-30-2016, 08:29 PM
  5. How can I get back into my Galaxy S6 Edge?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 03-30-2016, 06:27 PM
