1. kaiya4400's Avatar
    I deleted my os from my s3 please I need help I tried to reboot In recovery but it says no os installed. How do I fix this?
    08-08-2016 05:03 AM
  2. altobobcat's Avatar
    What did you do to delete the OS? When do you see the 'no OS installed error'?
    Oh and here is a solution.
    Find your stock firmware for your specific model number and your region(country) at Sammobile or at samsung-updates.
    Install Odin on PC.
    Make sure drivers are installed.
    Boot the device to download mode by holding the volume down+home+power button, when you see the caution screen press volume up to enter download mode.
    Connect your device to PC.
    Flash your stock firmware via Odin.
    08-08-2016 07:27 AM
  1. Replies: 0
    Last Post: 08-08-2016, 04:41 AM
  2. What happens after I clear my data
    Last Post: 08-08-2016, 03:54 AM
  3. Replies: 1
  4. Replies: 1
    Last Post: 08-08-2016, 03:45 AM
  5. Replies: 0
    Last Post: 08-08-2016, 03:09 AM
