1. blazianislander123's Avatar
    My Samsung Galaxy s3 isn't properly working when I turn it on it shows the logo screen then shuts off and vibrates it doesn't show the charging sign {the red light in the corner and the battery picture} I need help Please respond if you have any advice. Thank you.
    08-17-2016 08:47 AM
  2. srkmagnus's Avatar
    This sounds like a possible battery problem. But before you replace it, try clearing the device cache: https://support.t-mobile.com/docs/DOC-6205
    08-17-2016 09:45 AM
  3. kiisi's Avatar
    I reset my phone to factory settings inappropriately.It's a B LU. How do I get it back to function normally. When I turn it on, all I see is a the language option. Thanks
    08-17-2016 10:09 AM
  4. blazianislander123's Avatar
    I tried that but when I tried to turn the phone off the logo screen showed then cut off
    08-17-2016 11:11 AM
  5. blazianislander123's Avatar
    Also i tried two different batteries
    08-17-2016 11:57 AM
  1. Replies: 3
    Last Post: 08-24-2016, 04:06 PM
  2. Replies: 2
    Last Post: 08-24-2016, 12:11 PM
  3. android n 7.0 os massage app on send and receive videos
    Last Post: 08-24-2016, 09:19 AM
  4. Replies: 1
    Last Post: 08-17-2016, 12:03 PM
  5. Replies: 1
    Last Post: 08-17-2016, 10:06 AM
