Phone is a recently-purchased S3 Mini in "mint" condition. Yes, it's old but it still had some of the original packing tape to prevent scuffs on the metal trim. Looks like it was hardly used.
I charged it with the Samsung wall charger. It will only charge to 95%. From there it will discharge at the normal rate. I compared it to a friend's fully-charged S3 mini, both running only the Google maps app. Both used the battery at the same rate, only mine started at a lower charge.
Occasionally the phone will charge to 100% but it will not stay there. Still plugged in and charging, it will slowly drift back to 95% (even in airplane mode & no apps running). At 100%, if I unplug the charger and immediately plug it back in, I get a popup saying "The battery is fully charged, please disconnect the charger". I don't get that when it shows 95%, indicating that the OS knows the battery is not yet fully charged (and the 95% is not just a calibration error).
The same symptoms occur if I try to charge with an lower-amperage LG charger or my computer's USB port.
Suspecting the battery, I purchased a replacement. The date on the battery was 4/22/15 and the contacts looked brand new. Surprisingly, that battery will only charge to 90% (occasionally to 95%, but then drifting back down as above).
Many Google searches have not turned up anything useful. Any help would be greatly appreciated.
