1. steve767's Avatar
    hello. I am unable to tether my old s3 via usb to my laptop. I could do it before. I went to settings and looked for more settings but more settings is not visible on my phone. I can connect via hot spot but just not tether.
    04-25-2020 05:47 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Just to be sure -- the phone is still able to connect to the web via mobile data? When you connect the phone to the computer via USB, does the computer register that something has been connected?
    What version of Windows is your laptop running? When you used to do it before, was that a while ago (like on Windows 7), or not too long ago? The S3 is a really old phone, so I'd wonder if something has become incompatible with more recent Windows updates.
    Laura Knotek likes this.
    04-25-2020 04:47 PM
  3. steve767's Avatar
    hello. I'm running win 10 on laptop and win 7 on desktop. Up Until a couple of weeks ago I was able to tether to both for a long time. I went to device manager and network adapters and it shows an unknown device. Tried updating, disable/enable. its having this problem on win 7 and 10. I can hotspot to laptop but not desktop
    04-25-2020 10:39 PM
  4. B. Diddy's Avatar
    Have you also tried different USB cables?
    04-25-2020 11:52 PM
  5. steve767's Avatar
    yes. I've changed cables. Still no luck
    04-27-2020 10:21 AM
  6. B. Diddy's Avatar
    See if this helps:
    04-27-2020 12:00 PM
  7. steve767's Avatar
    See if this helps:
    That seems to have worked. Thanks
    B. Diddy likes this.
    04-28-2020 10:36 PM
  1. Calendar sync problem, System update 21
    By Sandman333 in forum Samsung Galaxy S9 & S9+
    Last Post: 05-01-2020, 11:40 AM
  2. Replies: 0
    Last Post: 04-24-2020, 04:34 PM
  3. How to i disable the stop watch on samsung gear s3?
    By Sajadk in forum Samsung Gear S3
    Last Post: 04-24-2020, 12:32 PM
  4. Charging problem Galaxy A20e
    Last Post: 04-22-2020, 12:19 PM
  5. AndroidCentral having logon problems?
    By Android Central Question in forum Site Feedback & Help
    Last Post: 04-21-2020, 07:07 PM
