1. 2Tall_TityBoi's Avatar
    Is anyone having trouble sending MMS with their GS4/GS4 Actives?
    Sent from my Samsung Galaxy S4 Active
    06-28-2013 01:41 PM
  2. str8bucs's Avatar
    I have the S4 and I have a problem while sending on WIFI, it never wants to send
    07-02-2013 10:26 AM
  3. Joe_Perone's Avatar
    MMS can't sent over Wifi, it's data only.
    I have a GS4, and I have no problems sending MMS.
    07-02-2013 11:32 AM
  4. str8bucs's Avatar
    I didn't have the problem with the S3
    07-02-2013 11:47 AM
  5. Joe_Perone's Avatar
    MMS is strictly a data issue though, it has to go through the carrier to be sent. No matter how much you wait, it will never send through Wifi. Maybe your data was on in the background, or your phone automatically turned it on to send MMS. I do know for a fact that you absolutely need a data plan to send MMS. Sorry
    07-02-2013 11:54 AM
  6. Almeuit's Avatar
    Yeah it is odd... It depends on how they set it up. Here is why I say that.
    On my Sprint S3 I could send via wifi with no mobile data... Then a update was released and if I was on wifi it would kick on mobile data, send the MMS, then cut it back off (I'd see the wifi symbol and the 3g symbol.. This is how I knew it was doing this). So basically mobile data was needed.
    I recently switched to the HTC One and now I can send over wifi.. It sends in a second and no data connection icon. I even tried with mobile data off.. And it worked.
    So I've concluded it really depends on how they set it up.
    Sent from my Sprint HTC One using AC forums.
    07-02-2013 12:05 PM
  1. Nexus 4 Keyboard Problems...Help
    By ron spencer in forum Google Nexus 4
    Last Post: 04-12-2016, 10:46 PM
  2. Not happy with the phone.
    By mawil1013 in forum Google Nexus 4
    Last Post: 07-02-2013, 11:52 AM
  3. Replies: 23
    Last Post: 06-30-2013, 09:09 AM
  4. Actionable notifications with Touchwiz text app
    By Jaime Compton in forum Verizon Samsung Galaxy S4
    Last Post: 06-28-2013, 10:31 AM
