1. quietlybrilliant's Avatar
    One simply can't compare the Active and regular S4 at half brightness. The Active is about twice as bright. Turning it to 25% brightness would make for a more accurate tests. I checked it out in the store today. Equally, at 100% brightness the regular S4 is as bright as the Active is at 50%. There is no doubt in my mind that Samsung opted against AMOLED because it is useless in daylight -- here in CA even the Active is borderline bright enough on a sunny day.
    With all that said, turning the Active to 40% brightness and regular to 100%, the two are comparable in brightness and the AMOLED screen looks far crisper.
    07-04-2013 12:01 AM
  2. Photon4glover's Avatar
    That whole review was bad
    Sent from my SAMSUNG-SGH-I537 using Tapatalk 2
    07-15-2013 10:01 AM
  3. ghostshell's Avatar
    What review? Its brighter so you can see it better underwater
    07-15-2013 08:03 PM
  4. Photon4glover's Avatar
    Just search s4 active review Engadget
    07-15-2013 11:17 PM
  1. Replies: 8
    Last Post: 05-13-2014, 05:30 AM
  2. N4 battery. What do you make of this?
    By justmikey in forum Google Nexus 4
    Last Post: 07-05-2013, 06:00 PM
  3. Replies: 0
    Last Post: 07-03-2013, 11:32 PM
  4. Samsung Galaxy Ace Snapchat-Camera flash isnt working?
    By bfitz93 in forum General Help and How To
    Last Post: 07-03-2013, 10:50 PM
  5. Replies: 0
