1. Wael Zorik's Avatar
    I have Samsung 4s 19500 but I wont to know if it work with 4g network because the LTE option does not appear in my option
    Model number : GT-I9500
    Android : 4.4.2
    Baseband ver. : I9500XXUGNF6
    KERNAL VER.3.4.5-2434847
    Please if any one had solve this problem inform me
    Thanks in advance
    01-14-2015 06:41 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The specs say GSM/HSPA, but no LTE: Samsung I9500 Galaxy S4 - Full phone specifications. HSPA+ is considered by many carriers to be 4G, although it isn't usually as fast as LTE.
    01-15-2015 01:28 AM
  3. Wael Zorik's Avatar
    there is no way to do any thing ????
    should be changed that you min my friend
    01-15-2015 02:36 AM
  4. B. Diddy's Avatar
    No, you can't add LTE to hardware that doesn't support LTE. It's important to know exactly what you're buying, especially when it comes to Samsung devices, because they can have many different versions of the same model of phone. These different versions are intended for different geographic regions and/or carriers, and some of those versions won't have the same radios, since not every region in the world uses the same carrier technology.
    01-15-2015 02:47 AM
  1. Replies: 3
    Last Post: 01-15-2015, 08:00 AM
  2. Samsung Galaxy Note 3 will not power on after update
    By dorothyrs in forum Verizon Samsung Galaxy Note 3
    Last Post: 01-14-2015, 09:47 PM
  3. Suggest protective case that fits with charger cover?
    By ewh111 in forum Samsung Galaxy Note 4 Accessories
    Last Post: 01-14-2015, 09:13 PM
  4. Replies: 1
    Last Post: 01-14-2015, 06:36 PM
  5. Nexus 5 Lollipop - GPS batter gone in an hour
    By purmar in forum Google Nexus 5
    Last Post: 01-14-2015, 05:51 PM
