1. MICHAEL KEULER's Avatar
    I recently put a new hi-cap battery in my s4 active and found it completely drained and turned off in the morning. I then put another "new" hi-cap battery in and this is what I found this morning. I have had these batteries before with no problems. Does anyone have any ideas. This phone is at least 4 yrs. old.Battery drain, complete, overnight.-screenshot_2015-09-21-10-09-15.jpg
    09-21-2015 10:21 AM
  2. MICHAEL KEULER's Avatar
    wow, not even a smart a## answer like your dictionary app was on all night, DUDE!
    09-23-2015 12:15 PM
  3. mullet4evr's Avatar
    4 year old phone? S4 Active came out in 2013.
    I have the same phone and had been experiencing bad battery issues for at least 2-3 updates. I finally decided to do a factory reset and my battery problems have dissapeared! Wish I would've decided to do the wipe sooner!
    P.S. Uninstall that dictionary app!
    10-08-2015 03:29 PM
  4. cord27's Avatar
    Yes, it seemed like I had it longer than that, but you're right, just a couple years old. I don't know what it was with the battery. I probably didn't close the app and the batteries are fine. I updated to 5.0.1 lollipop and have very good battery life.
    10-08-2015 05:26 PM
  1. Battery Concern in Z1 after 5.1.1 Update
    By Haider Shafaq in forum Sony Xperia Z1
    Last Post: 10-10-2015, 04:05 AM
  2. Replies: 2
    Last Post: 09-21-2015, 08:37 AM
  3. Is this app actually draining my battery?
    Last Post: 09-21-2015, 07:04 AM
  4. Samsung Galaxy S6 Edge Battery Life
    Last Post: 09-21-2015, 06:48 AM
  5. Replies: 1
    Last Post: 09-20-2015, 08:20 PM
