1. shady90's Avatar
    Hi!
    Some days ago my phone is suddenly died. :-(
    Now it is in bootloop, I cannot enter in recovery mode but I can enter in Odin mode.
    I tried to flash from odin different recovery (CWP, TWRP). The installation was successful, but after reboot I still cannot enter in recovery mode.
    Can anybody help me?
    Phone never rooted or flashed.
    GT-I9195 LTE - European (Italy)
    Original firmware, original rom, always updated.
    CURRENT BINARY: Samsung Official
    SYSTEM STATYS: Official
    KNOX KERNEL LOCK: 0x0
    KNOX WARRANTY VOID: 0x0
    CSB-CONFIG-LSB: 0x30
    BOOTLOADER AP SWREV: 2
    WRITE PROTECTION: Enable
    Thank you,
    Daniele
    03-18-2016 04:16 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Did you already try downloading and installing the stock firmware from SamMobile? Firmware for Samsung GT-I9195 - SamMobile
    03-18-2016 11:56 PM
  3. shady90's Avatar
    Thank you @b.diddy, yes I already tried and nothing changed :-(
    03-19-2016 03:02 AM
  4. B. Diddy's Avatar
    Do you have an SD card inserted? If so, try removing it and rebooting--sometimes a corrupt card can cause problems like that.
    03-19-2016 04:57 PM
  5. shady90's Avatar
    No sdcard inserted.
    03-20-2016 03:57 AM
  6. Wm7Long's Avatar
    My S4mini (GT-I9190) is very touchy about exactly how buttons are press'd and especially released in order to actually get into recovery mode. (I'm using CWM v6.0.5.1 by arco68.) I have found it necessary to press exactly as follows:
    Begin this process with power off (remove battery, wait awhile, replace)
    1a. Press & hold Volume Up. While continuing to hold,
    1b. Press & hold Home. While continuing to hold (both),
    1c. Press & hold Power.
    2a. Continue to hold all 3 until device starts up (it vibrates).
    2b. Release power button (keep holding other 2 buttons) during vibration*.
    3. Release other buttons when blue Recovery Mode appears.
    * Vibration lasts a second or two, release only the power button during latter part of vibration, or very shortly after vibration ends.
    03-20-2016 09:04 PM
  1. Replies: 8
    Last Post: 03-19-2016, 01:27 PM
  2. What app to use to BU data and app from old phone ?
    By billyjoebob007 in forum Samsung Galaxy S7 edge
    Last Post: 03-18-2016, 05:31 PM
  3. Smashed my phone
    Last Post: 03-18-2016, 04:05 PM
  4. Replies: 0
    Last Post: 03-18-2016, 03:52 PM
  5. Need to reset password on Galaxy Edge7.
    Last Post: 03-18-2016, 03:05 PM
