1. mangrove84's Avatar
    Hi, my S4 mini started producing loud crackling noises instead of playing music/sounds. The weird thing is that they don't appear always. E.g. when I reboot the phone the start-up music plays fine (most often) and the sounds works for a minute or two, e.g. the bing-sound when changing the volume. But then, without warning, suddenly only loud crackling noise comes from the internal speaker. Every now and then it goes away for a few seconds and works normal again, but then it returns to this terrible crackling noise.
    I have already done a hard reset, which hasn't changed anything. SIM card and SD card are removed and the problem is still there.
    What can I do?
    10-29-2016 02:58 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try booting into Safe Mode, which temporarily disables all 3rd party apps. https://support.t-mobile.com/docs/DOC-27781
    If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
    mangrove84 likes this.
    10-29-2016 09:15 PM
  3. mangrove84's Avatar
    The problem is still there in Safe Mode. I guess I'll have to return it... bugger.
    Thanks!
    B. Diddy likes this.
    10-30-2016 10:24 AM
  4. B. Diddy's Avatar
    You could also try reinstalling the firmware using either Samsung Kies (http://forums.androidcentral.com/amb...sung-kies.html) or Odin (http://forums.androidcentral.com/amb...interface.html). But if you have the ability to return or exchange it, that's probably easiest.
    10-30-2016 02:29 PM
  5. mangrove84's Avatar
    Would this somehow impact the warranty (reinstalling the firmware)?
    I can get the phone exchanged but this would take time and be somewhat complicated.
    10-30-2016 05:02 PM
  6. B. Diddy's Avatar
    I'm not sure, but since you don't have to root the phone, I think the warranty will still be valid. This thread might help: https://www.reddit.com/r/GalaxyS3/co..._through_odin/
    10-30-2016 06:16 PM
  7. mangrove84's Avatar
    Lol, Kies comes immediately back with "GT-I9195 does not support initializing".
    Well, then I'll return it.
    11-04-2016 04:51 AM
  8. B. Diddy's Avatar
    One other thing to try is Smart Switch: SmartSwitch: Install & update or replace firmware. (I'm never quite sure which devices are compatible with Kies and which ones are compatible with Smart Switch.)
    11-04-2016 11:36 PM
  1. Replies: 6
    Last Post: 11-01-2016, 11:27 AM
  2. Problem - Notification and ringtone sound
    By joklun in forum Nexus 6P
    Last Post: 11-01-2016, 02:08 AM
  3. Replies: 1
    Last Post: 10-29-2016, 09:18 PM
  4. How to open a factory locked screen of Samsung S4?
    Last Post: 10-29-2016, 01:02 PM
  5. Replies: 1
    Last Post: 10-29-2016, 12:14 PM
