1. wikey's Avatar
    Hey,
    Thought I would give rooting a go this evening, followed all the instructions and but ended up failing.
    Screens attached, can anyone advise what I have done wrong?
    Cheers
    Paul
    Sent from my GT-I9505 using Tapatalk 2
    05-14-2013 05:42 PM
  2. scorpiodsu's Avatar
    Hey,
    Cheers
    Paul
    You look rooted to me. Do you have superuser installed? Also download an app called rootchecker to make sure.
    05-15-2013 11:07 AM
  3. wikey's Avatar
    If you notice there is a failure on the screen shot, superuser is installed but when I install titanium back up its says it hasn't got root access.
    Any ideas would be much appreciated.
    Paul
    05-15-2013 11:43 AM
  4. scorpiodsu's Avatar
    Paul
    Yeah but it also says exploit completed. That why I suggested to download root checker to see what it says. Otherwise, I'm not sure what you would do besides uninstalled superuser and then trying again. In an one click tool so it's not easy to diagnose like a process with several steps to follow. Also I would suggest following the developer's thread for help. Good luck.
    [ROOT] Root Samsung Galaxy S4 with Motochopper - xda-developers
    05-15-2013 11:47 AM
  5. JRoss Francisco's Avatar
    Have the same problem. Rooted my S4 via mac and windows, both having the same errors respectively. I get this same error log with Windows. When I check it with root checker it tells me not rooted properly. Hope could get a solution for this. Many thanks!
    06-10-2013 03:31 AM
  6. Paul Wike's Avatar
    Hey,
    Are you using firmware ending in MDM? if so use the below link and you will be fine.
    CF-Root Download
    I had the same problem but this works just fine
    06-10-2013 08:39 AM
  7. Paul Wike's Avatar
    Sorry posted from my other account above.
    06-10-2013 08:48 AM
  1. Problems Root?
    By Anastasi G in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 10-18-2010, 08:27 PM
  2. Problems Root?
    By Anastasi G in forum Verizon Droid Incredible
    Last Post: 10-18-2010, 07:44 AM
  3. Having Problems Rooting
    By drano#AC in forum AT&T Captivate Rooting, ROMs, and Hacks
    Last Post: 08-31-2010, 12:39 PM
  4. Bluetooth problem - rooting fix?
    By Jase in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 08-02-2010, 10:37 AM
  5. Problems Rooting
    By knicks5171#AC in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 06-30-2010, 04:07 PM
