1. benhaw's Avatar
    For those who noticed lag on your stock s4 and who have rooted your phone, did the lag situation change at all? Everyone seems to blame touch whiz so it would seem to me if you ran a custom ROM that would fix the problem. Let me know if you have any insight.
    06-17-2013 02:18 PM
  2. srkmagnus's Avatar
    Rooting in itself will not resolve the lag situation. What you can do once rooted is install custom ROMs, which are enhanced TW iterations or based on AOSP, like Cyanogenmod, and have no TW.
    06-17-2013 04:50 PM
  3. gollum18's Avatar
    No it won't. Generally unless you know specifically what you are doing, it will actually slow it down.
    There's two kinds of routers. Users and developers. Users just root to use the features that developers make available, and they often times (not always) know very little about the root process or what root exactly means.
    Developers root for the specific purpose of developing. It's far easier to test/develop apps on a device if it is rooted. That way you have full access to the device, and can do exactly what you want.
    I would recommend if you do want to root, to educate yourself on the rights and responsibilities you have when you root your phone. Also you should learn exactly what it is and what it does.
    Sprint GS3 Running TN's Msg and Chubbs
    06-17-2013 07:09 PM
  1. exactly what does rooting do to your phone?
    By ooak in forum HTC EVO 3D Rooting, ROMs, and Hacks
    Last Post: 02-10-2012, 11:32 AM
  2. What does root really do for you? / vs. updating phone
    By plong#AC in forum Droid Charge Rooting, ROMs, and Hacks
    Last Post: 09-26-2011, 09:14 PM
  3. Root just for Lag fix?
    By CommandDelete#CB in forum AT&T Captivate Rooting, ROMs, and Hacks
    Last Post: 02-13-2011, 01:29 PM
  4. Rooted with old lag fix...
    By Glorfindale in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 01-21-2011, 10:46 AM
  5. What does "Rooting" your phone actually mean?
    By Magnious in forum Software Development and Hacking
    Last Post: 01-31-2010, 10:25 AM
