1. Levi Alvarado's Avatar
    Ok yes im rooted and whenever I go to bootloader screen even trying twrp all I get is hard reset or reboot now with the android laying down with a red triangle and an exclamation mark. Im trying to flash 4.3 but I cant get past this.
    07-10-2013 12:26 AM
  2. AdventAndroid's Avatar
    Can you access your bootloader without the red triangle
    Posted via the amazing Android Central App
    07-10-2013 12:58 AM
  3. AdventAndroid's Avatar
    I just read a post that might be relevant to your situation but I need to know if you are a Verison model trying to update to ( VRUAME7 )
    07-10-2013 01:05 AM
  4. AdventAndroid's Avatar
    If so you are in trouble
    http://forum.xda-developers.com/show...&postcount=536
    If you are verison; you'll have to wait for an exploit to root again (I hope you Backed Up your data)
    07-10-2013 01:10 AM
  5. AdventAndroid's Avatar
    Based on all this; I infer your root (SuperUser) tried to survive the OTA through "Survival Mode" and caused a NaNDroid. Since there's no new root method for your current firmware, you are unfortunately... well... out of luck unless you have a backup of BEFORE you updated, unless you have to wait for a new root method :-(
    Don't know if this will work but you could wipe your ROM through a Root-Toolkit on your computer (if you can access the bootloader) and download the one before the update
    http://forum.xda-developers.com/show....php?t=2292707
    (Cannot say it the Official but it dose say *Disclaimer: no apks have been edited this is a FULL STOCK ROM that you would expect to get from verizon*
    or you could get a new one. (Good chance to see how Cyanogenmod, Paranoid, or AOKP work for you... if of course you get this far)
    07-10-2013 01:33 AM
  6. AdventAndroid's Avatar
    If you know the pacifics on what your phone is you can always use this link instead of the others
    http://whatswithtech.com/how-to-unro...ung-galaxy-s4/
    The links for the ROM's are at the bottom of the forum under "firmware"
    07-10-2013 01:44 AM
  7. AdventAndroid's Avatar
    Sorry for so many posts but this might help also
    http://forum.xda-developers.com/show....php?t=2265477
    07-10-2013 01:47 AM
  8. Levi Alvarado's Avatar
    All I did was root so far but I didnt back up before I did a root. My phone works just fine I just cant flash a new rom.
    07-11-2013 02:26 AM
  1. [LEAK] "48 hours of worry-free battery life"
    By Phil Nickinson in forum Motorola Droid Ultra
    Last Post: 10-09-2013, 04:56 PM
  2. Help me understand apps on sd
    By tcm1969 in forum Samsung Galaxy S4
    Last Post: 07-10-2013, 04:37 PM
  3. Help!!! Red triangle with exlcamation
    By Levi Alvarado in forum Samsung Galaxy S4 Google Edition
    Last Post: 07-10-2013, 01:47 AM
  4. Replies: 5
    Last Post: 07-09-2013, 10:52 PM
  5. Help with pop up notifications with Handcent SMS on the S4
    By Camdog916 in forum Samsung Galaxy S4
    Last Post: 07-09-2013, 09:02 PM
