1. Medicine_Man_420's Avatar
    Hi all,
    I'm having a problem getting Antutu Benchmark to run on my S4. It's strange because it worked for several days while I was trying to optimize my CPU governor settings, and then out of the blue, if I click on "test" it immediately minimizes the app to an icon at the top tool bar and additionally it says "testing" in the notifications center, but it never actually runs a test. If I open it back up while I see the icon in the top bar then the app will either crash or just appear to be starting up for the first time.
    I've reset all the changes I made to the CPU/GPU with KTweaker and have also tried reinstalling Antutu, but I still get the exact same end result. I'm not sure if this is relevant but despite the fact the benchmark test seems to fails each time, the 'Stability Test' runs without any problem.
    I'd prefer to use the Antutu app due to the fact I can make simple comparisons between my results and what is expected or what others are getting. Basically, the scores are standardized and that simplifies the optimization steps - reach as high a # as possible, without compromising battery life....
    If anyone has any suggestions I would appreciate it. Also, just FYI i'm running ForceRom, and the phone is a sprint SPH-L720 running VPUAMDL
    Thanks!!!
    07-15-2013 09:12 AM
  2. Bizzle69's Avatar
    have you tried to go to settings>apps>antutu and clear cache/data?
    07-15-2013 10:41 AM
  3. Medicine_Man_420's Avatar
    yep, and unfortunately that didn't help either. I also tried giving it administrative rights, still no luck...
    07-15-2013 05:43 PM
  1. Replies: 1
    Last Post: 01-05-2014, 12:46 PM
  2. Getting an S4: Are the problems still there? Your experieces?
    By quynhuong in forum Samsung Galaxy S4
    Last Post: 08-27-2013, 02:33 PM
  3. Contacts display problem in Android
    By Najam Khan2 in forum The Android Central Lounge
    Last Post: 07-22-2013, 09:15 AM
  4. HTC One Battery Problems
    By kim31227 in forum HTC One M7
    Last Post: 07-15-2013, 06:52 AM
  5. SMS Major Problem - Randomly stop receiving text messages
    By LoopBack127 in forum General Help and How To
    Last Post: 07-15-2013, 12:41 AM
