09-27-2016 10:25 AM
27 12
tools
  1. Dankees's Avatar
    I haven't tested this out since it worked fine on my S3...so a grabbed my USB OTG cable and plugged it into my S4:
    1) Plugged in a 16GB USB 3.0 thumb drive. Immediately the stock file explorer popped up and showed me the root directory of the drive. I was able to play MP3s on that drive no problem. Seems working 100%.
    2) I plugged in both of my 2.5" USB drives, 1TB and 500GB. Each one turned on and the drive spun up...but my S4 said they were empty. I don't believe the USB on the phone can supply enough power to those drives for them to work properly.
    3) I plugged in, one at a time, my mouse and keyboard from this computer. I was able to control my device with each one immediately.
    I am currently on Goldeneye 4.0 ROM...just flashed it actually...no data restored, nothing installed, just 100% stock and factory wiped Goldeneye 4.0. I'd be surprised if there's any difference with the above if I switched back to stock AT&T MDL.
    So, you were able to at least play music with your Galaxy S4 but not operate a large external hard drive?
    09-27-2016 09:42 AM
  2. anon(632115)'s Avatar
    To run a large ext HDD they will need their own power supply for it to work. The Sammy has insufficient power for this
    09-27-2016 10:25 AM
27 12
  1. Chomp SMS Help
    By BitchImFatJesus in forum HTC One M7
    Last Post: 11-12-2015, 08:46 AM
  2. I rooted my s4 and this happened...
    By Jyu_Viole_Grace in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 09-20-2013, 11:04 AM
  3. iBolt dual USB cable thingie and phone calls
    By RobFreundlich in forum Samsung Galaxy Note 2
    Last Post: 07-25-2013, 08:30 AM
  4. FREE! PHOTO GENIUS: The Photo Editor
    By MariyaNcube in forum Android Apps
    Last Post: 07-17-2013, 05:50 AM
  5. Please help testing this app~
    By Viviansvr in forum Beta Requests
    Last Post: 07-17-2013, 04:20 AM
