09-27-2016 09:25 AM
27 12
tools
  1. Medicine_Man_420's Avatar
    Hi all,
    I know this is a totally noob question but im trying to figure out if I can read/write to an external USB drive plugged directly into my phone?? (Sprint S4 SPH-L720, rooted and flashed with ForceRom)
    I've used file explorer to find the USB after plugging it into the phone, but I can't seem to locate any of its contents....could I just be over looking them, or would they not be displayed?
    When I search for "How to Guides" all I can find are instructions for enabling Mass storage, which allows for direct file transfer between your desktop and the S4s' external SD card, and unfortunately that's completely unrelated to what I'm trying to do.
    Any help would be appreciated, thanks in advance!!
    -Mike
    07-17-2013 08:15 AM
  2. Brian Lam's Avatar
    Is it a USB 2.0, or 3.0? Because there shouldn't be a USB port on the S4. It's only a micro usb i think
    07-17-2013 08:53 AM
  3. Medicine_Man_420's Avatar
    So far I've only tried using a USB 2.0....you're right about the connection type, the S4 only has a micro USB but I'm using a little adapter to interface the two connections (as seen here: Amazon.com: Afunta(tm)android Tablet Cable Adapter Set-micro USB Otg; Mini USB Otg; Hdmi Female to Micro Hdmi Male;hdmi Mini-enabled Devices to Standard Hdmi: Electronics )
    Any ideas??
    07-17-2013 08:59 AM
  4. Medicine_Man_420's Avatar
    Anybody...? I'm sure I'm not the only one who wants to access USB files from an S4
    07-17-2013 11:33 AM
  5. enotar's Avatar
    You cant. The micro usb is for charging and HDMI with a special adapter
    Sent from my SGH-I337M using Tapatalk 4 Beta
    07-18-2013 08:15 PM
  6. angry mustache's Avatar
    Wrong. Unless my S4 is messed up and wrongly lets me plug a keyboard, mouse, and some USB flash drives with no issues. With the OTG adapter, most of my flash drives can be read without issue. My SanDisk Titanium drives do not see to be recognized for some reason, though.
    Mythgyver likes this.
    07-22-2013 06:14 PM
  7. the53rdcard's Avatar
    with that OTG adapter you should be able to read it, but im not sure if that is a rooted feature or not, i can do that with my touchpad and cm9, but the big thing is, for the drive, you HAVE to have external power as the phone/tablet port will not provide enough for the drive to work. So you can get a powered usb hub, and a splitter cable, or one of those portable battery packs and a splitter cable and it will work
    here is a site that shows how to set it up on the touchpad, i wont have my s4 for a week so i cant speak to how different it will be on that, but it at least is a place to start REVTV - How To Set Up USB Host Mode on the HP Touchpad
    07-27-2013 10:32 AM
  8. jeffreii's Avatar
    Hi all,
    -Mike
    I haven't tested this out since it worked fine on my S3...so a grabbed my USB OTG cable and plugged it into my S4:
    1) Plugged in a 16GB USB 3.0 thumb drive. Immediately the stock file explorer popped up and showed me the root directory of the drive. I was able to play MP3s on that drive no problem. Seems working 100%.
    2) I plugged in both of my 2.5" USB drives, 1TB and 500GB. Each one turned on and the drive spun up...but my S4 said they were empty. I don't believe the USB on the phone can supply enough power to those drives for them to work properly.
    3) I plugged in, one at a time, my mouse and keyboard from this computer. I was able to control my device with each one immediately.
    I am currently on Goldeneye 4.0 ROM...just flashed it actually...no data restored, nothing installed, just 100% stock and factory wiped Goldeneye 4.0. I'd be surprised if there's any difference with the above if I switched back to stock AT&T MDL.
    07-27-2013 11:38 AM
  9. angry mustache's Avatar
    I would think a powered USB hub would be able to provide enough juice to spin up a portable USB hard drive. Either that, or an external power supply source for the drive itself. I know my older external drives had a jack to plug in a power supply if you couldn't plug in both ends of the split USB cable into the computer.
    And for the record, I am able to read and write to my SanDisk Cruiser drives plugged in through the OTG cable. Still puzzled why the Titanium sticks won't work right, though.
    07-27-2013 12:03 PM
  10. davidsnoodles's Avatar
    It might be the formatting of your USB drive. I'm not sure what formats the S4 can and cannot read, but you might want to double check that.
    08-03-2013 11:08 PM
  11. angry mustache's Avatar
    This may be the case. One of the drives I couldn't read before was reformatted either FAT or FAT32, and works just fine now. It may have been exFAT or some other MS format before.
    08-05-2013 05:58 PM
  12. robgub61671's Avatar
    download usb otg helper its for rooted devices and you can read any file structure fat 32 or ntfs or if you dont have root you have to format the flash drive to fat 32 and yes you can use an external hardrive as long as its powered just plug it in to your otg cable and open usb otg helper and click mount
    08-11-2013 02:01 PM
  13. reconminicon's Avatar
    I was wondering, when I had my ZTE Blade with CMrom when I plugged it into my PS3 I was able to copy files from it. Not sure if it was the rom. But when I plug my S4 in it does not show up as a USB device on the PS3. Any ideas?
    Sent from my GT-I9505 using AC Forums mobile app
    08-20-2013 07:55 PM
  14. RichardTheGreat's Avatar
    I don't know all the formats it can read. It CAN read FAT32. It CANNOT read NTFS.
    11-03-2013 01:39 AM
  15. tech_head's Avatar
    Reading USB drives does work.
    If it's an actual drive you might need a powered USB hub.
    If it's a flash drive it should just work.
    You will need a USB OTG adapter for about $3.00
    11-04-2013 01:19 AM
  16. RobN's Avatar
    This is kind of off-topic - the rest of the messages are about using the phone to read USB drives, not having the phone act as a USB drive.
    The S4 doesn't use the standard USB mass storage device driver, so you need a computer that can detect the connection type it's advertising. If you're rooted, you can get an app called "USB Mass Storage Enabler" that lets the phone acts as a normal USB mass storage device, and that would probably work - but only for the external SD card, not for internal memory.
    11-06-2013 12:00 PM
  17. Hiram Escamilla's Avatar
    Its funny that you guys have had to power your external hard drives with either the powered usb hub or through the power adapter, I have used a 60 gb and a 500gb drive connected directly to the phone and both spun up and i was able to read and write to them no problem, they were both 2.5 drives so maybe they need less power, my battery did start draining pretty fast though.
    11-28-2013 01:21 PM
  18. Igmu's Avatar
    You can purchase or make your own micro USB OTG cable.
    They normally cost around $5 to purchase.
    DIY USB OTG CONVERTER FOR i9100! IT WORKS! - xda-developers
    The device needs to have the ability to host the USB connected device.
    Determine Your Phone’s USB Host Capabilities With USB Host Diagnostics – xda-developers
    I apologize for linking to a foreign thread, but this is where I found the answers to your question.
    01-15-2014 05:08 PM
  19. mrsmumbles's Avatar
    There's also the Sandisk micro SD and SD WiFi thing. It connects over WiFi I think. It is pricey though.
    Sent from my LG-LG870 using Tapatalk 2
    01-15-2014 05:20 PM
  20. GarySFP's Avatar
    I have an OTG cable and I used to connect my flash drives to my phone all the time but now it has stopped working. However I bought an ikross Kross Micro USB 2in1 OTG SD Memory Card Reader For Samsung Galaxy S4 S3 Note 2 and it reads everything and cost 8 bucks on ebay
    03-10-2015 05:13 PM
  21. david green15's Avatar
    I have a Monster flash drive that has the micro connector at one end and the other end is the regular usb plug.
    04-14-2015 10:33 PM
  22. Dngrsone's Avatar
    I have one of those, too, but my case prevents me from trying it with the S4...
    Sent from my SPH-L720T using Tapatalk
    04-15-2015 05:27 PM
  23. D_DemoCrazy's Avatar
    my s4 was able to read any Pen drive while connected before it was rooted.. after rooting... it doesn't detect.. definitely a root problem or software. let me know how u solved it !
    12-23-2015 11:19 AM
  24. fingertrick's Avatar
    Somehow i doubt unless your root method was so terribly written that it breaks features like usb host, WiFi, etc... you're not taking about root. However!! Do you by any chance have a custom rom or system configuration root apps that access the system partition such as.. 3c toolbox or rom manager.. Basically I'm asking you, are you regardless of using a recovery that can install roms, using a rom or flashing any files to maybe modify system files?
    01-04-2016 03:51 PM
  25. Mythgyver's Avatar
    I have a S4 i337m and I can run any usb device I've tried. I bought an OTG cable from Radio Shack for $10. Logitech trackball (mouse pointer appears on the s4 screen), Western Digital Passport drive gets enough power to run, all thumb drive and microsd cards with adapter (both USB 2.0 and 3.0 work just fine) I rooted and flashed CM12.
    02-18-2016 07:52 AM
27 12
  1. Chomp SMS Help
    By BitchImFatJesus in forum HTC One M7
    Last Post: 11-12-2015, 07:46 AM
  2. I rooted my s4 and this happened...
    By Jyu_Viole_Grace in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 09-20-2013, 10:04 AM
  3. iBolt dual USB cable thingie and phone calls
    By RobFreundlich in forum Samsung Galaxy Note 2
    Last Post: 07-25-2013, 07:30 AM
  4. FREE! PHOTO GENIUS: The Photo Editor
    By MariyaNcube in forum Android Apps
    Last Post: 07-17-2013, 04:50 AM
  5. Please help testing this app~
    By Viviansvr in forum Beta Requests
    Last Post: 07-17-2013, 03:20 AM
