1. Derek11598's Avatar
    How to Root Verizon Galaxy S4 SCH-i545! [UPDATED with VIDEO] | GalaxyS4Root.com
    Ive been using this tutorial http://galaxys4root.com/galaxy-s4-ro...-s4-sch-i545/\
    and it keeps failing here are the logs<ID:0/004> Added!!
    <OSM> Enter CS for MD5..
    <OSM> Check MD5.. Do not unplug the cable..
    <OSM> Please wait..
    <OSM> SCH-I545_MD2_423399_Kernel.tar.md5 is valid.
    <OSM> Checking MD5 finished Sucessfully..
    <OSM> Leave CS..
    <ID:0/004> Odin v.3 engine (ID:4)..
    <ID:0/004> File analysis..
    <ID:0/004> SetupConnection..
    <ID:0/004> Initialzation..
    <ID:0/004> Get PIT for mapping..
    <ID:0/004> Firmware update start..
    <ID:0/004> boot.img
    <ID:0/004> NAND Write Start!!
    <ID:0/004>
    <ID:0/004> Complete(Write) operation failed.
    <OSM> All threads completed. (succeed 0 / failed 1)
    07-30-2013 09:35 AM
  2. Bizzle69's Avatar
    I had this issue as well, but eventually got it. Just keep trying, you'll get it
    07-30-2013 05:35 PM
  3. davidsnoodles's Avatar
    What Build are you on? It's in the About phone section. If you're not on VRUAMDK, then the root method you're using isn't the proper one for your Build. If your build is VRUAME7, then you need to follow a different method. Here is the complete and essentially fool-proof guide to rooting ONLY VRUAMDK BUILDS. Here is the complete and essentially fool-proof guide to rooting ONLY VRUAME7 BUILDS.
    VRUAME7, I believe, is the new update that allows apps to be installed to your SD card. It's more convoluted than if you were just on DK vs E7, but it's completely doable.
    08-03-2013 11:06 PM
  4. Derek11598's Avatar
    I got this error
    cant execute: is a directory
    08-06-2013 11:34 AM
  1. Samsung Galaxy S3 Mini not starting
    By Maskatul Gaming in forum Samsung Galaxy S3 Mini
    Last Post: 08-22-2013, 10:44 PM
  2. Any way to play gameloft games from the sdcard without root?
    By Silithas in forum Samsung Galaxy S4
    Last Post: 08-03-2013, 01:48 AM
  3. Just rooted, flashed ARHD 12.1 and now firmware question?
    By Nutzer in forum HTC One Rooting, ROMs & Hacks
    Last Post: 07-30-2013, 03:29 PM
  4. Keep root while updating?
    By M1grande in forum Google Nexus 7 Tablet (2012)
    Last Post: 07-30-2013, 11:55 AM
  5. YouTube problem!
    By binaryn00b in forum Samsung Galaxy S4
    Last Post: 07-30-2013, 11:49 AM
