1. Android_S4's Avatar
    Hi everyone, I rooted my cell phone succesfully, and today the cam stopped working. every app related to the cam wont work. Tried everything. Unrooted and reseted the cellphone, still nothing.
    My cell phone is the Samsung Stock Model, not modded by any carriers.
    Please, Im desperate... couldnt find any bugfixes or firmwares to update it
    Thanks
    08-14-2013 10:48 PM
  2. Android_S4's Avatar
    Here is how i fixed it.
    1 - removed root
    2 - factory wipe
    3 - at www.samfirmware.com I downloaded my country stock firmware
    4 - running odin 3.07 as system adm click the PDA key.
    5 - look for the folder where you extracted the .tar.md5 file (it comes compressed in .rar)
    6 - kill kies on task manager
    7 - connect the phone to your pc in download mode (vol down home power button)
    8 - click start on Odin
    9 - wait for it to flash and you phone to reboot
    10 - open your cam... it should be fixed.
    Hope it helps.
    08-16-2013 11:03 PM
  1. need some advice from the wise ones...
    By myIphone4s in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 09-03-2013, 05:00 PM
  2. [SOLVED] Help with Music Library
    By brinith in forum General Help and How To
    Last Post: 08-27-2013, 09:55 PM
  3. Cell Phone Dash Cams - Anyone Done?
    By streetslide in forum General Help and How To
    Last Post: 08-14-2013, 10:38 PM
  4. Replies: 3
    Last Post: 08-14-2013, 09:57 PM
  5. screen help
    By jar425 in forum Samsung Galaxy Note 2
    Last Post: 08-14-2013, 06:36 PM
