1. myIphone4s's Avatar
    well thanks to hashcode over on xda he has figured to get roms on the mf3 build, so now i would like to root i followed the thread on xda for root, expect i didnt remove my sd card, i dont have a reader or adapter just usb cable, so i pass the first line and fail the rest why is that, i can go to my files and i can see the files i have extracted,
    i need help guys, to get this device rooted, i really dont want to lose my stuff on the sd card. thank yall for the much needed help
    09-18-2013 11:56 AM
  2. myIphone4s's Avatar
    sorry about the title i wanted to be very clear i am on mf3 build,
    09-18-2013 12:15 PM
  3. ScottsoNJ's Avatar
    You need to format the Sd card to exFat. Here is the process
    New Root Method for AT&T Samsung Galaxy S 4 (OTA MF3) - xda-developers
    09-19-2013 10:38 PM
  4. myIphone4s's Avatar
    thanks but as you can tell i have a tab open on that and i dont have a micro reader, or hub. i dont know why i need to format it, i wonder if i can do it through windows 7
    09-20-2013 08:32 PM
  5. billinaz's Avatar
    Copy your stuff on the SD card to your computer. Format the SD card to ex fat and then do the root.
    Return the stuff to your sd card from the computer.
    09-22-2013 11:20 AM
  6. myIphone4s's Avatar
    ya i was trying to do it through my phone while retaining my data on my sd card (i didnt find my reader), but i found my sd card adapter and rooted it now i wish i had the 32gb phone or wait till hash code figures out a way to save data and use an sd card.
    09-24-2013 10:10 PM
  1. New guy questions
    By Hot94Z28 in forum Verizon Galaxy Nexus
    Last Post: 01-07-2013, 01:21 PM
  2. Battery Life Issues, what are you guys running?
    By ptm88 in forum Verizon Droid DNA
    Last Post: 12-17-2012, 09:21 AM
  3. Replies: 1
    Last Post: 12-13-2012, 12:32 AM
  4. What have you guys found to be the best case?
    By Karrott9 in forum Google Nexus 4
    Last Post: 12-12-2012, 07:49 PM
  5. Welp guys, I dun goofed.
    By atomic_squid in forum HTC One X Rooting, ROMs, & Hacks
    Last Post: 12-08-2012, 02:53 PM
