1. MistahDonutsx's Avatar
    Does anyone know how to change the signal icons in CyanogenMod?I want to "4G" icon to show LTE and the "H" icon to be 4G. Thanks in advance
    10-08-2013 11:30 AM
  2. srkmagnus's Avatar
    CM allows you to change the icon from 4G to a predefined text (not "LTE"). If you want it to say LTE you need to edit the .xml files/graphics that would be associated with such a change. That's out of my scope, perhaps there is a theme in the Play Store with that mod built in.
    10-08-2013 11:46 AM
  3. MistahDonutsx's Avatar
    Tried one called "ROM Toolbox pro" and it rebooted with the 4G LTE icon from Verizon but it didn't work
    10-08-2013 01:15 PM
  4. srkmagnus's Avatar
    Ah, yeah, that means you probably need to root the device and install a custom ROM/theme to have the LTE icon instead of the 4G icon.
    10-09-2013 10:29 AM
  5. MistahDonutsx's Avatar
    I am rooted, but it still didn't work. Booted into recovery and told me to flash the LTE icon file and it said reboot, icons were the same
    10-10-2013 12:21 PM
  1. email icon not showing number of emails
    By bszaronos in forum Samsung Galaxy Note 3
    Last Post: 01-11-2019, 11:36 AM
  2. How to lock Note 3 to LTE/4g signal?
    By zef05 in forum Samsung Galaxy Note 3
    Last Post: 07-24-2016, 06:59 PM
  3. how to change the icons on the bottom homescreen bar?
    By wwu97 in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 11-22-2014, 09:54 AM
  4. Mixing Icon Packs?
    By TechTinker in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 10-08-2013, 12:05 AM
  5. The "N" icon is for NFC being enabled
    By Blackintuit in forum Samsung Galaxy Note 3
    Last Post: 10-07-2013, 08:10 PM
