I just moved in to my Galaxy S4 after years of Motorola, starting at the Droid X.
Over there, filenames on the external SD card looked like this in Tasker:
../../sdcard-ext/[foldername/][filename].[extension], for example ../../sdcard-ext/records/boring.txt.
This isn't working on my GS4.
What should I be using in Tasker instead of ../../sdcard-ext?
Thanks in advance!
edit: The answer is /storage/extSdCard
Thanks in advance!
