1. Hammertime52's Avatar
    Ill list my ordeal so its easier to read
    >Rooted Galaxy S4
    >Downloaded proper rom for my model ([ROM] I9500 Galaxy S4 OzcanRom v4.2 Aroma XX… | Galaxy S4 | XDA Forum)
    >Loaded ROM onto Internal Storage
    >Boot into Recovery
    >Wipe Data, Cache, Delvik Cache
    > Install Zip from Internal Storage
    >Everything goes good, Says ROM is installed and were good to go.
    > It reboots and im stuck at the "Samsung Galaxy S4" boot screen
    I know the first reboot takes a while but this screen NEVER GOES away. I reboot into recovery and wipe delvik cache and same result. I retry to load it and nothing. Also sometimes during the installation of the ROM it will say there is no root, but I use several root checkers and they all say Im rooted. Any ideas?
    08-24-2014 09:22 PM
  2. mremghz8787's Avatar
    Check to make sure that the room you downloaded was downloaded correctly. Use am md5 checker, or use esfile Explorer and open the zip file. If it can't open it then download the rim again.
    08-26-2014 10:58 PM
  3. trucky's Avatar
    How can your root checkers say you're rooted if you never get past the boot screen?
    08-27-2014 11:55 AM
  4. Bizzle69's Avatar
    make sure you wipe Cache, Delvik Cache, system and factory reset in recovery (this is the method I use in TWRP), and then install the rom.zip.. if you still have issues, redownload the rom like mremghz8787 mentioned
    08-27-2014 08:06 PM
  1. app problem
    By evoldroid in forum LG G3
    Last Post: 08-25-2014, 12:18 PM
  2. accessing pictures from galaxy s4
    Last Post: 08-24-2014, 08:05 PM
  3. HELP! can't install custom rom
    Last Post: 08-24-2014, 06:42 PM
  4. Best rom for sony xperia z?
    By Daniel948984 in forum Sony Xperia Z
    Last Post: 08-24-2014, 06:04 PM
  5. Can't install ROM on TWRP (Xperia S)
    By fishbowl38 in forum Ask a Question
    Last Post: 08-24-2014, 05:41 PM
