1. Omer San Gabriel's Avatar
    Planning to root my phone using CM 11. This will be the first time that i will be doing a root. But before that, i've search that CM 11 on the S4 drains more battery than stock touchwiz. Is this True?
    09-15-2014 11:30 PM
  2. Golfdriver97's Avatar
    I wouldn't think so. It also depends on when people are reporting this. After a fresh flash, the ROM will be doing a lot in the background just setting up with the new kernel and such. So right after a flash is a bad time to report battery drains.
    09-15-2014 11:42 PM
  3. Omer San Gabriel's Avatar
    I've read it here Cyanogenmod 11 - reduced battery life on Galaxy S4 - Mobile Devices - Linus Tech Tips
    I'm planning to do the easy root of cyanogenmod here. "http://beta.download.cyanogenmod.org/install" is this good? I don't know much about rooting.
    09-15-2014 11:52 PM
  4. Golfdriver97's Avatar
    I would say make a Nandroid, and flash away. I had no problem with CM and battery life.
    09-15-2014 11:58 PM
  5. Omer San Gabriel's Avatar
    Nandroid? Sorry but 0 knowledge rooting. =)) Can you give me some links on how to root S4? i9505 specifically.
    09-16-2014 12:00 AM
  6. Golfdriver97's Avatar
    Here are a few things to look over: http://forums.androidcentral.com/amb...-recovery.html
    GalaxyS4Root.com - Learn How To Root Samsung Galaxy S4, install custom ROMs, and more!
    The root link: look up the method for your model number. Any questions, by all means ask.
    Omer San Gabriel likes this.
    09-16-2014 12:03 AM
  7. Omer San Gabriel's Avatar
    So what should i do first? The first link or the 2nd link?
    09-16-2014 02:10 AM
  8. Golfdriver97's Avatar
    I would get the phone rooted first. The root procedure usually involves flashing a custom recovery. Make a Nandroid, then you should be close to being able to flash a new ROM.
    Read the rooting instructions carefully and several times.
    09-16-2014 09:35 AM
  1. Battery drain problems on LG G3?
    By ree3312 in forum LG G3
    Last Post: 08-30-2016, 05:38 PM
  2. IMS Framework draining my Battery on Galaxy S4
    By Steve 4 in forum Samsung Galaxy S4
    Last Post: 10-17-2014, 09:16 AM
  3. Updated touchwiz
    By keyzlife in forum Samsung Galaxy Note 3
    Last Post: 09-15-2014, 06:48 PM
  4. htc one xl evita showing 787 mb ram when installed cm 11
    Last Post: 09-15-2014, 04:29 PM
