1. daylebo5's Avatar
    Hi All,
    Problem: Wifi is not switching on my Galaxy S4 (I9505). It's been grayed out and I'm unable to switch it on.
    Actions taken: I've been researching and trying to resolve this problem non stop for nearly 24 hours. I've done the following:
    - Upgraded my stock to CyanogenMod 11 since I (naively) thought it would rectify the wifi problem. (cm-11-20141008-SNAPSHOT-M11-jflte)
    - Updated my modem to the latest one I could find (I9505XXUGNG2_MODEM)
    - Installed the wifi fix (I9505XXUGNG8_WIFI_FIX)
    - Tried a bunch of other suggestion (e.g. using sqlite to change some setting values.)
    No sure what more I can do, and I'm starting to think it might be a hardware problem?
    Are there any more suggestions? Or is there any way to debug it and find out if it's an hardware problem?
    Appreciate any help I could get , coz this is driving me crazy!
    11-08-2014 04:12 AM
  2. hamza malik4's Avatar
    Iam also having the very same issue.
    And I dont know what to do.
    Have your problem solved???
    If yes then please help me aswell.
    As nobody here is replying to my thread.
    12-21-2014 01:07 PM
  1. [Free][App]USA Zip code on your Mobile
    By mz4Mobile in forum Android Apps
    Last Post: 05-18-2017, 12:44 PM
  2. do you use pedometer on your note 4?
    By thegame161 in forum Samsung Galaxy Note 4
    Last Post: 11-10-2014, 09:42 AM
  3. how much you getting out of your battery on average
    By currentdroiduser in forum Samsung Galaxy Note 4
    Last Post: 11-09-2014, 03:52 AM
  4. My HTC M8 power button is not working
    Last Post: 11-08-2014, 07:29 PM
  5. S3 Mini keeps Retarting while mobile internet data is on ?
    By jyothujinadevan in forum Ask a Question
    Last Post: 11-08-2014, 05:35 AM
