1. flaxie's Avatar
    hi,
    my S4 i9500 won't boot.
    i have tried loading several versions of stock roms, recoveries and non-stock roms.
    all stock roms fail in odin, and i get "unsupported dev_type" error on the device.
    other non-stock roms install with no error, but the device won't boot after reboot.
    finally, out of frustration and recklessness, i guess i used an S4 boot loader fix wihch loaded successfully from odin.
    unfoutunatly, after rebooting the device, boot message sais GT-I9505 instead of GT-I9500. turns out it was a 9505 boot loader fix.
    is there anything i can do to bring my device back to life??
    currently, device won't boot to recovery (blue "recovery booting" on top left corner of screen), won't boot to system, but can enter download mode, and be identified by odin.
    thanks!!
    12-29-2014 10:08 AM
  2. Rukbat's Avatar
    Find a 9500 recovery, flash that, wipe cache, factory reset, then try to get it replaced.
    12-29-2014 10:25 AM
  3. flaxie's Avatar
    already tried that, both cwm and twrp. both won't load, and still i get gt-i9505 on boot screen
    12-30-2014 03:46 AM
  4. flaxie's Avatar
    i found the problem. its my pc
    i tried on another pc, and manged to load stock rom on the device.
    could be driver problem, will check and update soon, thanks for the help guys!
    12-31-2014 11:29 AM
  1. Ne Help needed to restore back to stock om
    By n4cer26 in forum Sprint Galaxy Note 2
    Last Post: 01-13-2015, 10:30 PM
  2. HELP!!! water damage, SCREEN TURNS ITSELF ON
    By compadremax in forum Verizon Samsung Galaxy Note 3
    Last Post: 12-31-2014, 03:13 AM
  3. Do I need to replace my battery on my Galaxy S4?
    By Haris Begic in forum Batteries
    Last Post: 12-30-2014, 12:18 PM
  4. HTC Desire Eye or Samsung Galaxy A5
    By ColdSummer in forum Phone Wars
    Last Post: 12-30-2014, 10:45 AM
  5. Why isn't my Galaxy S4 turning on after syncing Whatsapp history?
    By NuggyTubb in forum General Help and How To
    Last Post: 12-29-2014, 05:26 AM
