1. louij2's Avatar
    Hi,
    I was trying to reinstall the Stock Samsung Firmware 02U 5.0.1 using Odin and I would get a Pit error so I downloaded the file and would still get another error so I decided to reboot, instead of the device getting stuck on the glowing Samsung splash screen it goes straight to the error
    Firmware upgrade encountered an issue. Please select recovery mode in Kies & try again.
    It also says in the corner
    ODIN MODE
    PRODUCT NAME: GT-I9505
    CURRENT BINARY: Custom
    SYSTEM STATUS: Custom
    KNOX KERNEL LOCK: 0x0
    KNOX WARRANTY VOID: 0x1
    CSB-CPNFIG-LSB: 0x30
    WRITE PROTECTION: Enable
    eMMC BURST MODE: enabled
    I need help so that I can get it all back to stock and sell the phone!!!
    Much help greatly appreciated.
    06-27-2015 06:53 AM
  2. louij2's Avatar
    Bump need help really quick 😢
    06-28-2015 02:56 AM
  3. louij2's Avatar
    Bump 😣
    06-29-2015 11:56 AM
  4. louij2's Avatar
    Bump
    07-02-2015 01:41 AM
  5. louij2's Avatar
    Bump
    08-10-2015 11:05 PM
  6. louij2's Avatar
    Bump please
    08-29-2015 04:38 AM
  7. louij2's Avatar
    Bump
    09-15-2015 12:13 PM
  8. sowhatthehell's Avatar
    all you need to do is to turn off your phone then turn it back on pressing the down volume button and the power button
    10-01-2015 02:58 AM
  1. Cell Standby battery drain - PLEASE HELP!!!
    By bkircher in forum Google Nexus 6
    Last Post: 10-16-2015, 02:31 PM
  2. Zenphone 2 incompatibility issues (games)
    By Lebron Curry in forum ASUS ZenFone 2
    Last Post: 07-03-2015, 02:52 AM
  3. When is the Emerald Green edge available in the U.S?
    By icellphones32 in forum Samsung Galaxy S6 edge
    Last Post: 06-30-2015, 07:35 PM
  4. Lost fast forward/back buttons in Smart Audio Player
    Last Post: 06-27-2015, 03:42 AM
  5. Can't select wifi option after lollipop update?...
    Last Post: 06-27-2015, 01:20 AM
