1. Raithed's Avatar
    Hi all, I have an S4 that is rooted, and I was trying to unroot it, after Odin failed twice, my phone got stuck in the error screen. Currently, it is stuck in Odin mode:
    Product Name: SGH-M919
    Current Binary: Samsung Official
    System Status: Official
    KNOX Kernel Lock: 0x0
    KNOX Warranty Void: 0x1
    CSB-CONFIG-LSB: 0X30
    Write Protection: enable
    eMMC BURST mode: enable
    "Firmware upgrade encountered an issue. Please select recovery mode in Kies & try again."
    The phone basically is disconnected from the USB, my PC does not see it anymore. I downloaded Kies and it does not work (USB cannot be detected). I also tried holding down the Volume Up, Home and Power buttons - no good, it goes back to the screen.
    Volume Down, Home and Power buttons.
    I downloaded my firmware from Androidrootz (4.4.2 - M919UVUFNB4)
    Any help is greatly appreciated.
    EDIT - Thank you for reading, I have fixed the issue by using another machine
    12-19-2015 10:52 PM
  2. AnnieCP22's Avatar
    Hi! I just came upon your post, and I am stuck exactly at the same place you were, any insight on how you solved your problem would be very appreciated, I would have liked to post a link to my original post on this forum but apparently I can't. If you go look under my posts, you'll see it
    "HELP ! Samsung Note II - Stuck with Firmware upgrade encountered an issue. Please select recovery. What can I do?"
    Thanks !
    12-21-2015 08:35 PM
  3. Icone's Avatar
    Try to use a different machine if ODIN isn't working for you.
    12-25-2015 12:44 AM
  4. thiengly998225's Avatar
    If you are on official firmware samsung you can use allsamsung recovery download the file go to Odin press pda locate the file then start I had the same problem with you after trying to downgrade my s4 mini I unbrick my s4 with this file very good file
    04-25-2016 08:08 PM
  1. Incorrect storage showing in setings
    By DaEXfactoR in forum Nexus 6P
    Last Post: 01-06-2016, 02:55 AM
  2. LG G2 2 issues
    By chetc in forum LG G2
    Last Post: 12-21-2015, 08:36 AM
  3. Rooted? Diag Mode? CP Logging? Menu Selection
    By yazoforums in forum Samsung Galaxy S5
    Last Post: 12-19-2015, 11:29 PM
  4. Can you wipe your phone screen with an antibacterial wipe?
    Last Post: 12-19-2015, 08:02 PM
