Price-wise, but as can be seen not really quality-wise. (Depends on the plastic as there are many different kinds.)well plastic is cheaper.
What exactly does having a pentile arrangement do? I know it's different then rgb but what does it do? Better color saturation?
Courtesy of My LT3VO
Ok, but is what I said true about pentile v. RGB?I hope this makes sense I broke it down as simple as I could think of it.
OLED materials are still in development., in the early 90s a red material would be activated and die(or degrade) within seconds. Now red materials live millions of hours , while green lasts less longer and Blue degrades the fastest.
In an RGB layout all subpixels are of equal size so if a certain color degrades faster it would be noticeable. Think of it like red green and Blue are each a tank of gas . Red tank would stay full the longest and Blue may run out of gas long before the other two.
With pentile they were able to make different size subpixels instead of being uniform like in an RGB layout. So basically giving blue a bigger gas tank so it would go longer to keep up with red and green.
Since increasing the size of blue subpixel left obvious gaps they compensated by splitting up green and filling gaps this Became known as a RGBG layout.
Then then the next question would be why were they able to use rgb on the note 2. Since the resolution was only 720p they were able to use larger size pixels.
But in order to do 1080p they would need to reduce the size of the subpixels which caused the original problem of blue dying quickly(the whole small tank analogy).
With the S4 they configured the subpixels differently to fillin more gaps and create a higher resolution while protecting the lifetime of each color.
From my Galaxy Note 2 via Tapatalk
For any given brightness, lower power consumption. And for any given number of subpixels, higher resolution.
What about the second part - for any given number of subpixels, higher resolution. I wasn't sure if that was correct, but I read it on a manufacturer's website so I thought it had to be.Yes because since green pixels are more efficient and more abundant you can receive a brighter image without cranking up the power.
Good enough for me. To me the One only wins by a small amount overall with the Xperiz in a close second.and the S4 in a close third.Pentile also brings with it a noticeable decrease in sharpness (less subpixels per inch). It is still apparent (admittedly only with close observation) that the S4 is not as sharp compared to its 1080p LCD peers. Check out the phone arena comparisons. Not as bad as the SIII (which looked pretty bad in comparison) but the problem is still there.
http://i-cdn.phonearena.com/images/reviews/130061-image/screen-comparison-galaxy-s4.jpg
They have a zoomed in comparison on their page as well. The problem is much more apparent there. Still, don't think this will be too visible in everyday use.
I think since they are talking about RGBW in that article and not RGBG that same principle does not apply.What about the second part - for any given number of subpixels, higher resolution. I wasn't sure if that was correct, but I read it on a manufacturer's website so I thought it had to be.
Here is where I read it
Pentile Technology - What Does It Do?
I also notice on my GNex that whites look bluish when viewed from an angle but when viewed straight on. What causes that effect?
Really...what different does it make to the average user ??? most of the people are not experts like you ............ most of us want a good phone with good features better than the previous one ............. most of the people is interested in battery life, better camera, better reception, SD card and removable battery.Samsung has lost their minds! Who in the world puts a Pentile display on a phone in 2013?
They shot themselves in the foot here.
I was brave and went up to my local VZW store tonight (the reps there are mean, rude, pushy and scary) and checked out the DNA's screen. I held my GNex next to it and wow, the DNA does have a nice screen compared to my GNex. It is just so much clearer and brighter. But I would have to see it outside to know if the glass was reflective or not.
Still, I love my GNex's make believe colors.
