I know that the new battery in the S4 will be 2600 mAh compared to S3's 2100 mAh,
But can you use the S3 battery in the S4.
It seems to be the same size, the phones are close to similar size as to the battery area.
I have multiple batteries from the S3 which would be nice to continue using on the S4.
I dont know if the upgrade from the S3 to S4 is worth it without losing the oppurtunity to use the extra batteries.
I am a power user and switch batteries often and I really do not want to buy more batteries in the near future. :-\
