- Mar 9, 2013
- 102
- 0
- 0
Looking at the major 2013 release phones this year it has pretty much come to my conclusion that the phones are pretty much at there peak for a while,we have come to main stream 4 cores now and pretty much have peaked at lipo tech in the battery segment also.
lets take a look at what Samsung has done,they have nearly doubled its specs and jammed it all into a slightly smaller shell then its older borther the gs3.
This is a great accomplishment but what can Samsung do next for the gs5? we have so much cpu power now that the gs4 will most def be able to run the next 3 versions of android and they can do a die shrink in the next 2 years to get there octo core to clock higher and stay in the same voltage envelope but I feel that they have finally hit a peak and will stay here for about a year or two.
they can shave off a little bit more bezel in the gs5 and shave a little bit from the top and bottom and keep it a 5in screen but I think 5in will be here for a while and the phablets will just get a little bigger.samsung left ony a few options on the table for a gs5 and Im sure people will not get the same WOW factor on the next galaxy cell.I mean we have 2 versions now and one is sporting a exynos soc that on paper is about 15-20% faster yet the snapdragon s4 can do everything the octo can without the end user knowing the difference,so the spec war is basically at its peak now and no one will care when one phone opens an app 1/10s of a second faster.
I can see htc and lg added micro sd cards back in and going removable batteries but what else can they do either?I think its kinda like computer cpus now and even a cheap I5 chip can make a computer run and feel just as fast as a i7 chip to the end user.
What I would like to see in the next galaxy cell is a 5in screen with just a slightly shorter shell and maybe a carbon fiber front bezel and aluminum around the sides and keep the plastic back cover,but other then that I just don't see the next gs5 or any other flagship android cell wowing anyone after this year.Trust me guys android is also heading to the same position that apple is in but apple has so many areas to improve on while android pretty much all ready threw everything at the wall with the latest flagship phones.
this is the first time that I think I will get a new phone and not need to upgrade it do to hardware limitations and wonder how companies will wow people from this point on
