1. Ramiatweh's Avatar
    Hi all.
    I'm in Australia. In our stores we will be getting the i9505 model, LTE + Snapdragon Quad.
    In all honesty, I'm not overly fussed with LTE as it chews battery life and is still very limited here in Aus, DC-HSPA will be more than sufficient for my needs.
    So here is my quesion...
    Will the i9500 support DC-HSPA speeds of up to 42Mbps or will it just be standard HSPA 21?
    I'm looking around and everyone seems to have a different answer!
    Cheers!
    04-23-2013 09:22 PM
  2. SpiralBorg's Avatar
    Its 3G, the Exynos version.
    Were are you buying the device? Mobicity?
    I'm in Australia, too.
    Sent from my MZ604 using Android Central Forums
    04-24-2013 04:33 AM
  3. Ramiatweh's Avatar
    Yeah I'm happy with 3g I just would like to know if it supports Telstra's MiMo or if it's just standard 21mbps 3g.
    I think I'll just stick to the standard 9505, I can get it sooner Haha.
    II was thinking Kogan, it's up for 799 (:
    But I'll probably just grab the 9505 from allphones.
    04-24-2013 04:47 AM
  4. SpiralBorg's Avatar
    Haven't heard about MiMo in a long time....
    Probably just 3G. I too am getting the Snapdragon version.
    Its still blazing fast.
    04-24-2013 05:04 AM
  1. What data speeds are you getting?
    By MattMJB0188 in forum HTC myTouch 4G
    Last Post: 12-20-2011, 02:11 AM
  2. Data speed in Minneapolis/St. Paul
    By thatguyjeff in forum General Carrier Discussion
    Last Post: 02-22-2011, 09:00 PM
  3. Improved Data speed?
    By akoni1p in forum AT&T ATRIX
    Last Post: 02-20-2011, 09:12 AM
  4. What is your data speed on 3g?
    By star444 in forum HTC EVO Shift 4G
    Last Post: 01-13-2011, 09:14 AM
  5. Really annoying CM6 Data Speed Issue. Need you help.
    By cd5love96 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 09-10-2010, 01:15 AM
