1. jackfrostxx's Avatar
    I am currently running my verizon S3 with Cyanogenmod, Is the S4 worth the price if I'm just going to run a custom rom dispelling most of the built in samsung features? I see the S4 as mostly a hardware upgrade, what do we think?
    04-27-2013 12:06 AM
  2. cole2kb's Avatar
    Probably not. I'd say the biggest difference you'll notice is the screen size. Wait until you're due for an upgrade and then see what's out there with CM support.
    04-27-2013 12:11 AM
  3. KoukiFC3S's Avatar
    Which version of cyanogen are you running? I had activation issues with m3.
    Do you have an upgrade available? I would upgrade for $200 but not at full retail.
    Sent from my SCH-I535 using Tapatalk 2
    04-27-2013 01:02 AM
  4. Kevin OQuinn's Avatar
    Might wanna wait and make sure Cyanogen is going to support the phone officially first.
    04-27-2013 07:41 AM
  1. Replies: 14
    Last Post: 12-09-2013, 02:11 PM
  2. Problem with Connecting to WiFi with WPA Enterprise
    By kra104 in forum Samsung Galaxy S3
    Last Post: 04-25-2013, 06:33 PM
  3. Replies: 3
    Last Post: 02-18-2013, 11:00 PM
  4. Recommend me apps to use with my S3
    By TanyaJayneP in forum Samsung Galaxy S3
    Last Post: 06-05-2012, 12:45 PM
  5. Replies: 6
    Last Post: 12-18-2011, 01:30 PM
