1. texasotts's Avatar
    I want to change my font on the phone and am not able to? Fontimizer doesn't work and none of the other fonts I download work? I even have the apk file for a bunch? Is it just too new that nothing is compatible?
    Sent from my SAMSUNG-SGH-I337 using Android Central Forums
    04-27-2013 10:46 PM
  2. texasotts's Avatar
    Anyone found any?
    04-28-2013 11:49 AM
  3. xcruiseme's Avatar
    Im having the same problem!!
    04-28-2013 11:52 AM
  4. Rashawn29's Avatar
    handwriting fonts work
    04-28-2013 01:52 PM
  5. FitMomXtine's Avatar
    I asked this too. I installed one and I saw it in the menu when I select fonts but when I press ok to select that font it says "font not available"
    This is the 3rd issue ive found with my phone & its starting to bug me.
    But I am aware that this is a new phone but I was hoping there wouldnt be too many kinks and bugs to work out since a lot of previous Samsung users told me this wasnt an issue.
    (When I was deciding between phones)
    Its still a hell of a lot better than my iPhone.
    04-28-2013 01:55 PM
  6. texasotts's Avatar
    Yes I can use the fonts that came installed on the phone but not any I install. I assume because it's new maybe they are not compatible. I download them and then install and can see them in my display settings under fonts but it will not use them. Just tells me it's not available
    I cannot stand stock fonts. I do a lot of websites and graphics so I guess I like the aesthetics a nice font gives
    04-28-2013 05:32 PM
  7. Dave Gates1's Avatar
    Have been crazy fighting this bug and been through variety of forums.
    Yes, it is that fonts have not caught up with S4 compatibility.
    Found the fix!!!
    I installed "IFont" app from play store.
    They JUST updated the app and the fix was for the S4 compatibility issue.
    The font I wanted was found in the Local fonts and when I set it to use and ReBooted the phone.......it took!
    05-09-2013 09:53 PM
  8. HOLLYWOODANT215's Avatar
    I just side loaded 5 fonts they was all fonts u had to pay for and the worked but its couple I really want I can't find
    05-09-2013 09:56 PM
  1. Droid- How can I change font sizes? app? settings?
    By rick707 in forum Motorola Droid
    Last Post: 03-06-2012, 03:09 PM
  2. drfoid advert font?
    By paradox460 in forum Motorola Droid
    Last Post: 12-31-2009, 09:13 PM
  3. Font size
    By o4liberty in forum HTC Droid Eris
    Last Post: 12-09-2009, 01:07 PM
  4. Samsung Moment is where font size on screen?
    By ilovesunflower in forum Samsung Moment
    Last Post: 11-07-2009, 06:11 PM
  5. Droid Font Size
    By brad9920 in forum HTC Droid Eris
    Last Post: 11-02-2009, 10:41 AM
