05-04-2013 07:05 PM
178 ... 34567 ...
tools
  1. shannon la's Avatar
    I use my droid all day and for the most part i have to be plugged in because by the second my battery is at one bar. I just bought this phone. It is fast, even on the battery.
    04-30-2013 06:38 PM
  2. shannon la's Avatar
    Sometimes you need to go to task manager and stop other programs from running. I did find that to be the reason for my quick power loss.
    04-30-2013 06:40 PM
  3. Calidoc's Avatar
    Managed to get that before it shut itself off. 6 hours of on screen time on the first charge cycle. That's almost in the Note 2 territory.
    Sent from my Samsung Galaxy S4
    Wow, you got twice the life I did. Doesn't mine seem bad? My iPhone 5 blew this out of the water.
    Attached Thumbnails Worst battery ever-image.jpg   Worst battery ever-image.jpg
    04-30-2013 08:38 PM
  4. return_0's Avatar
    That looks pretty unusual.
    Sent from my pure Google Nexus 4 using Android Central Forums
    04-30-2013 08:47 PM
  5. Calidoc's Avatar
    I have pretty poor reception at work, like 1or2 bars. But still, same reception on my iphone. I hope this improves because that's pretty awful.
    04-30-2013 08:56 PM
  6. Joe the Insider's Avatar
    There should be a rule where if you are speaking regarding your battery, you need to show proof (screenshot) too many trolls these days.
    The Hustleman likes this.
    04-30-2013 09:10 PM
  7. The Hustleman's Avatar
    Which phone so you have
    Sent from my SGH-T999 using Tapatalk 2
    04-30-2013 09:52 PM
  8. badbrad17's Avatar
    Anyone have any idea what's killing my battery so fast? Phone gets really hot too.
    Sent from my Galaxy S3 Life Companion
    It's your data. That burns way more than when on wifi especially LTE. Toggle your data off with a widget like widgetsoid or power toggles. It's fast and saves lots of battery.
    04-30-2013 09:55 PM
  9. The Hustleman's Avatar
    Which phone do you have
    04-30-2013 10:18 PM
  10. speed13's Avatar
    Sent from my Galaxy S4 White - using Tapatalk
    04-30-2013 10:34 PM
  11. planoman's Avatar
    Is the goggle maps for using navigation? That eats battery big time
    04-30-2013 10:37 PM
  12. Colonels's Avatar
    Try this:
    Power off phone, remove battery for 2 minutes, then put it back in.
    I have no idea why but this would fix random run away processes that killed my galaxy s3 battery exactly like what's happening to you.
    I'm getting about 12 hours usage screen using 71% total time screen on 4:40 hours
    04-30-2013 11:21 PM
  13. Calidoc's Avatar
    Without knowing the screen on time, I don't think those screenshots are too informative.
    Nope. I'm not sure what maps was doing.
    04-30-2013 11:39 PM
  14. TeamPowerstroke's Avatar
    Were you using the maps that much? On my first cycle of the battery I noticed google maps used around 30-40% battery and I didnt even use maps, Found out the latest updates of maps was causing this, uninstalled the update and battery life was a lot better...
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
    04-30-2013 11:45 PM
  15. planoman's Avatar
    Whatever it is doing it is eating your battery! Does the S4 Have a task manager like other Galaxy Phones? On my Note 2 I will periodically close all running apps and clear the RAM just incase there is a rouge app.
    04-30-2013 11:49 PM
  16. Ess_78201's Avatar
    It seriously balances out after a few days.
    05-01-2013 12:02 AM
  17. badbrad17's Avatar
    It's Google Now. Sucks life out of your phone and uses location services/maps.
    05-01-2013 12:39 AM
  18. speed13's Avatar
    05-01-2013 07:36 AM
  19. TEEMILL's Avatar
    I am highly impressed with the battery life on my s4
    Sent from my SPH-L720 using Android Central Forums
    05-01-2013 08:28 AM
  20. speed13's Avatar
    I'm happy with life of my battery so far.
    05-01-2013 08:36 AM
  21. JasW's Avatar
    The "Screen" entry on the battery page is a catch all -- you could be using apps like crazy and it would all show up as "Screen"
    05-01-2013 08:48 AM
  22. HeavemyTreo's Avatar
    The battery is so bad for a new phone just come from iphone 4s n tht phone lasted longer n that was over a year old
    I got my S4 yesterday, played with it for 6 straight hours downloading a bunch of stuff, trying out ever application and listening to music. My first impression was great battery. I moved from an S2, but seems like S4 is much better. I assume the battery will get better after the first charge. I did order another spare battery, I don't like the big extended versions. Sorry for your problems, there may be some setting that killing your battery?
    05-01-2013 09:08 AM
  23. meyerweb#CB's Avatar
    The screen entry is screen on time, nothing more and nothing less. If you keep your screen on that time will continue to rise even if you're not using any apps.
    05-01-2013 10:23 AM
  24. OhAlfie's Avatar
    My battery has been doing fine. When I unplug it at 6:30 a.m the phone ends the day (11:30pm) at aroudn 25%. Not too bad IMO.
    badbrad17 likes this.
    05-01-2013 10:28 AM
  25. JasW's Avatar
    That's what I'm saying -- it doesn't differentiate between whether you are doing something (battery intensive) or not, it all just shows up as screen on time.
    05-01-2013 10:34 AM
178 ... 34567 ...
  1. I am getting the worst battery life I have ever seen.
    By trigun123478 in forum Verizon Galaxy Nexus
    Last Post: 10-01-2012, 03:05 PM
  2. Worst phone ever!
    By kholzman in forum T-Mobile Sidekick 4G
    Last Post: 08-08-2011, 10:53 PM
  3. Worst launch ever?
    By richardschris in forum ASUS EeePad Transformer
    Last Post: 04-30-2011, 12:02 PM
  4. Vibrant (aka my best and worst phone ever)
    By Hidefcow in forum T-Mobile Vibrant
    Last Post: 03-19-2011, 04:39 PM
  5. Worst Article Ever!
    By n8mack33 in forum General News & Discussion
    Last Post: 09-16-2010, 06:52 PM
