JasW
The "Screen" entry on the battery page is a catch all -- you could be using apps like crazy and it would all show up as "Screen"
The battery is so bad for a new phone just come from iphone 4s n tht phone lasted longer n that was over a year old
The screen entry is screen on time, nothing more and nothing less. If you keep your screen on that time will continue to rise even if you're not using any apps.
Ya, that's why so much of this is subjective. Reading a book in Kindle is much less taxing on battery than playing games.That's what I'm saying -- it doesn't differentiate between whether you are doing something (battery intensive) or not, it all just shows up as screen on time.
I'm sorry but that's not 100% correct. I'll cut and paste some useful information.
Unlike NiCad batteries, lithium-ion batteries do not have a charge memory. That means deep-discharge cycles are not required. In fact, it?s better for the battery to use partial-discharge cycles.
There is one exception. Battery experts suggest that after 30 charges, you should allow lithium-ion batteries to almost completely discharge. Continuous partial discharges create a condition called digital memory, decreasing the accuracy of the device?s power gauge. So let the battery discharge to the cut-off point and then recharge. The power gauge will be recalibrated.
You must not have tried an iphone 5 on Verizon LTE...
The battery is horrible on this phone, I heard.
Search for them @ ebay.
Sent from my Samsung Galaxy S4 using Android Central Forums
Mine lasts several days without a charge easily. So does my iPad 4 on Verizon LTE. Certainly my iPhone 5 lasts longer than my loaner S4 on AT&T.
Anandtech shows the iPhone 5 on LTE at 8.19 hours in web browsing and the S4 at 5.6 hours.
OP, I suggest your provide more information. You may have a bad battery or faulty charging.
That looks pretty unusual.
Sent from my pure Google Nexus 4 using Android Central Forums
Is the goggle maps for using navigation? That eats battery big time
Try this:
Power off phone, remove battery for 2 minutes, then put it back in.
I have no idea why but this would fix random run away processes that killed my galaxy s3 battery exactly like what's happening to you.
I'm getting about 12 hours usage screen using 71% total time screen on 4:40 hours
Were you using the maps that much? On my first cycle of the battery I noticed google maps used around 30-40% battery and I didnt even use maps, Found out the latest updates of maps was causing this, uninstalled the update and battery life was a lot better...
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
So, as a follow up to my other screen shots on the thread, here are some from today. Mind you, I had GPS off most of the day, Wifi off most all day and even had power save on. My reception is poor, but a coworker has the S3 and doesn't have any problems with battery life and she has the same reception with same carrier. What's going on with this? At the 8% mark you see, my screen on time was about 90 mins, which is nothing. Does AT&T have replacement batteries in store? Should that be my first route (try a new battery)? But, this should not be happening...right (new guy from iPhone 5)?
Sent from my Galaxy S4 White - using Tapatalk
I'm not sure how to go about diagnosis. Shouldn't that be apparent on the screenshot above? It all seems normal I thought (in terms of how the programs are drawing from the battery).Something is constantly waking your phone, that's where you should start
Sent from my Note 2
My battery was dying pretty fast and i downloaded GSam Battery Monitor. Enables you too see which apps are draining power. There were a few samsung apps which i didnt use draining a lot of power so i disabled them. Might be worth some of you checking there is nothing draining it in the background
