Calidoc
you have a runaway process in your phone. in my gs3 it wouldn't always be the same thing, one time it was Handcent SMS widget, another time it was a widget that I didnt even have loaded, sometimes it would happen when i tried charging the phone from a car charger... it was really just random. bottom line is if the phone has been sitting idle for few minutes but feels warm to the touch, the processor is engaged and that is burning your battery.
Did you try the removing battery 2 minutes?
you can try holding down home button to task manager, trashing all the apps in memory, then clearing the ram. see if that helps?
You can also factory reset phone, remove all installed apps, just to see if it is an app causing it.
lastly return it for new one, could be defective
I did remove the battery for 2 minutes. I've also cleared the memory many times. Also, if there were a runaway process, wouldn't that be evident in the battery usage screen? I don't see any process using an inordinate amount of battery (unless I'm missing something).
This shows your GPS on the entire time? I'll bet the phone is heating up if the GPS is on the entire time? I do not see it in the top menu though.
I would try a reset and it that does not work I would exchange it. Something is not right.
Yeah, the GPS was I guess, which is weird because I had to turn it on when I left work because it was off.
If I do reset, would it defeat the purpose to restore from a backup from Kies?
