Calidoc
Calidoc
Do you have Air View and Split Screen and SMart Stay and those new features installed? What about Beautiful Widgets?
Those are the only things that I added yesterday when my phone decided to go crazy overnight, before that my phone worked great for 2 charge cycles.
I suggest turning them off / uninstalling them to see if it fixes your issues, although your GPS usage is strange as mine does not show that yet I am experiencing similar battery drain since last night.
I think your phone is bugged if you had GPS off but it still shows on. DO a factory reset.
Airview, smart stay and that stuff is off I do have beautifuk widget (2 going). I'll tl uninstall and see what happens.
edit: Sorry, I have 2 go weather widgets going. ***** Hey the point of widgets if they use so much battery that you can't run them.
