Disable Loud Volume Warning?
SCSnare
Active member
May 20, 2011
42
6
I hook up my phone in my car to use Spotify, but I keep getting a warning about extended listening at loud volumes being harmful. I can just hit ok and then turn up the volume again, but having to do this practically every other time I start listening to Spotify is annoying. Anyone know how to turn this warning off permanently?
Disable Loud Volume Warning? II
I'm looking for a resolution to this as well. I listen to Pandora, and my own Shoutcast stream and have to deal with the same BS while I'm trying to drive. This is a real hazard for a lame warning not to blow out your eardrums.
chunktvlive.com
Yes this is annoying. My volume randomly turns up and down along with the notification
Sent from my SCH-I545 using Tapatalk 4 Beta
It's so annoying, sometimes I listen to podcasts and I need the sound up a little higher since it's not music...
Also getting the notification - intermittently - on this VZW S4. Very annoying. PPL need to be complaining to VZW.
I'm rooted as well, and was about to load a ROM that didn't have this lol.
But it's annoying. So is the 5% perma-low brightness that you can't change.
After setting up adapt sound I can still get that same warning but I feel like it occurs at a much higher volume than before. I could be wrong though. I'm getting the warning now after hitting the volume + over 9 times from 0. Thats much higher than what I would normally ever use with headphones so I haven't even noticed it the last couple of weeks.
The default level for the warning is at "10", so that would be right where you're getting it.
Here are instructions for those rooted to remove it:
[GUIDE | TUT | HACK] Remove Android 4.2.x safe volume message - xda-developers
EDIT: Just tried this using the "easy" method (1st method), and it didn't seem to work on my S4...
Here's how I got around it. I use Poweramp for my music player. Thankfully it has a preamp and EQ so I just boosted the preamp a bit, tweaked the EQ a bit more and now the "default" sound level for music is high enough that I never get that annoying warning even when turning it up a fair bit.
Mine does it too, but it doesn't do it all the time. Once it comes once, it wont come on again until after a while. It's annoying when it does come on though.
Try going to a public place where the noise level is moderately high. Now go to your sound settings and Adapt sound. Now do the listening test, but basically click no to any sound you don't hear VERY well. That way you trick your phone into thinking you're partially deaf. That way you can turn the volume up without recieving the warning. It worked for me :p no modding required.
I have this issue as well. When Im riding my bike listening to music, my phone is in my pocket and I use the controls on my headphones to boost the volume. Its annoying when the volume won't go up, and I have to slow down or stop to get my phone out of my pocket and click the "ok"
I friggin' love you, thanks!
Why do we need a kludge to "fix" such a shonky "feature"? I have so much admiration for Android until they do something as stupid as this! At least if they feel like they must put a limiter on there to prevent them from being sued or whatever they should at least include the option to turn it off permanently, whereby it becomes the user's responsibility.
Well there is a more elegant solution: root and install a different ROM. That's the route I went. Installed Slim Bean and amongst the ton of other awesome features, is the removal of the high volume warning.
This did not work for me
nubiapk
