1. dvonbertrab's Avatar
    Hey guys!! I just changed from an iphone to the s4 and this being my first android device I am still getting used to it, but so far I am loving it! I wanted to know how you can get the percentage of the battery on the top of the screen? and is you have other cool tips and tricks I would be very grateful. thanks!!!
    04-28-2013 10:52 PM
  2. return_0's Avatar
    There's an app called Battery Widget Reborn that, among other things, adds a notification that shows your battery percentage.
    Sent from my pure Google Nexus 4 using Android Central Forums
    04-28-2013 11:01 PM
  3. Kevin OQuinn's Avatar
    BATTERY WIDGET REBORN
    I'm sure there are others, but that's the one that I use. I've had it for a while, so I can't remember if it's free or not, sorry.
    04-28-2013 11:02 PM
  4. dvonbertrab's Avatar
    thanks!!!
    04-28-2013 11:04 PM
  5. Love Divine's Avatar
    IIRC, it's an option in stock Touchwiz (why the hell don't other manufacturers do this??). Should be somewhere under power in the settings menu.
    Kevin OQuinn and onick like this.
    04-28-2013 11:39 PM
  6. kopkings123's Avatar
    Hi mate if u go to settings then display batt percentage can b found down near bottom n u can switch it on there hope that helps
    onick likes this.
    04-28-2013 11:55 PM
  7. onick's Avatar
    you DO NOT need to install another program to display percentage. go to your phone settings, go to "display". look for an option says, "display battery percentage". enable it. done.
    jcp007 likes this.
    04-29-2013 05:17 AM
  8. kopkings123's Avatar
    I said that
    04-29-2013 05:44 AM
  1. Battery Percentage instead of battery icon?
    By elder_shawn in forum HTC EVO 4G
    Last Post: 12-23-2011, 03:20 AM
  2. Adding battery percentage to battery icon?
    By cltatenza in forum T-Mobile G2
    Last Post: 10-05-2010, 02:20 AM
  3. Exact battery percentage on the EVO
    By mitch2k12 in forum HTC EVO 4G
    Last Post: 06-05-2010, 11:30 PM
  4. Battery Percentage
    By dman26 in forum HTC EVO 4G
    Last Post: 06-05-2010, 11:44 AM
  5. App For Battery Percentage to replace in notification bar?
    By surfacinglove in forum Verizon Droid Incredible
    Last Post: 05-11-2010, 10:46 AM
